Your views on the 1.6 105 and the 1.2 105 engines
I would go for the 1.2 petrol every day over the 1.6 diesel.
The reasons are:
Economical for a petrol.
Lively enough for daily driving.
Lighter so the car is better balanced, so handling is improved.
Quieter.
More refined.
Warms up faster in winter.
Available in DSG form which is a cracking combination, if you don't want a manual.
Cheaper to buy.
The only benefits of the diesel i my opinion are:
Cheaper to run.
More in gear torque for accelerating without changing gear.
Thank you think I will stick to the manual instead of the automatic also tuning it to 130 may be a option actually do you think this would effect the fuel economy and a big difference on insurance
  • Replies 68
  • Views 4.1k
  • I would go for the 1.2 petrol every day over the 1.6 diesel.   The reasons are:   Economical for a petrol. Lively enough for daily driving. Lighter so the car is better balanced, so handling is
  • It will all come down to what kind of journeys you are going to be doing.   The 1.6 is not suited to town driving due to the DPF (Diesel Particulate Filter) fitted.   I had a 1.6 in an Ibiza FR fo
  • I recently bought the 1.2tsi and very very happy with it. Coming from a 1.2 corsa, the monte is so much quicker and the torque is great. I wouldn't think that the 1.6 diesel is quicker? The tsi runs v
Minimal effect on fuel economy unless you trash it everywhere.
Insurance cost depends on your company.
130 from 105 is less than 25% so it's within what most insurance companies accept.
Always check before you do it though.
It might have helped to state yours was modified from the outset to avoid confusion. ;)
Signatures don't show on mobile devices, well not on mine anyway.
Didn't know that, live and learn :)
If you want reliable and economic transport you might want the Original or Used Car / Extended Warranty valid,
so best to just leave the 105 ps standard with the Petrol or Diesel and have Warranty Cover,
remapped the Warranty will be void on the engine.
Thank you yes I did fancy the vrs but too much insurance and not the reliability I want can't wait to start properly looking and test drive
Do you think the new fabia will change the cost of the mark 2 fabia
Well at first there won't be much if any difference. It takes a while before the new model sells in sufficient numbers to affect the prices of the superseded one.
Where there will be a noticeable saving will be on new Mk 11 models still in the system. Eventually the dealers will want these away so some good deals to be had but of course you would then be buying the 'old' model and could expect residuals to take a hit early on.
I would be proberbly buying second hand either from a dealership with a trade in or private I'm thinking leave it as it is then after the warenty runs out then possibly upgrade it if it will make a difference do they offer a standard Warrener on it or were you on about buying an extended warenty
You can buy a 'Skoda Approved extended Warranty' that Skoda sell and is actually a product from Car Care Plan ltd.
1 or 2 years at a time, if the car meets the age and Mileage conditions.
A 'Skoda Approved used car' should come with a 12 month Warranty.
Used cars under 3 years old from others should have the remainder of the Original Manufacturers Warranty,
or 5 years if the First Buyer extended it when they bought the car.
I have had the 1.6CR TDI 105 for nearly 4 years and have never driven the 1.2TSI.
If your journey is 7-8 miles each way you could struggle to keep the DPF happy unless you will do a much longer run every 2-3 weeks.
My daily commute is 11 miles each way and particularly over the winter only a very occasional longer run. I have never had the DPF light up but the regen does not complete in one journey. Had I known about the DPF, the regen cycle and its effect on fuel consumption I would have bought the TSI instead.
I bought with a longterm view so the higher purchase price was offset by the RFL saving hence any saving on fuel cost was money in my pocket. Since you will only be using around 10 litres a week with the current price differential between petrol and diesel your fuel cost saving using diesel would at best will be minimal
Another thing to consider as already posted is that the TDI is high geared. If your commute includes slow moving queues you could be constantly dipping the clutch while others keep rolling in 1st gear. On the open road the TDI needs to run above around 1700rpm so the turbo is spinning fast enough for best efficiency. Maybe the software has now been changed but the gear change indications on mine are far too early.
When I bought the DSG was not available on any diesel and the lead time was over six months so I did not consider it. If as now it was available on the 90PS ( I guess the 105PS can generate too much torque ) and the same lead time lead time I would have considered it.
Edited by delta925
Just as a side note mate.
The gear selection indicator thing is too early on all engines and hasnt changed.
I've got a 2013 and id labouring the engine if i shifted into 5th at 35mph like it suggests.
But thats for another topic i guess :)
I left my comment about the gear change indication open should it have been revised although I suspected not ...
5th at 35mph :no:
I don't go for 5th until around 55mph :happy:
Hmm that's strange Oli, mine indicates 3rd gear around 30mph, 35-40mph i think shows to change to 4th and around 50mph it shows to change to 5th? However i don't know if that's normal but every car is different i guess?
Thank you for that detailed reply I think this is a great topic for all those people who wanted to know the difference and how each of the engines can work for individual people. I have learn a lot from all your guys and girls to make me choose which would be best for me and also learn from others mistakes once again thank you
5th at 35mph :no:
Yup. Haha.
And mines a 1.2 HTP, so not got the torque at Tickover haha.
Depends how much you're pressing the accelerator i think
If tickling it at a steady speed, mine always thinks an up change is required, even if im doing 2k revs already.
Its uh, abit useless tbh.
Although sometimes if i floor it in 4th at 2-3k revs, itll show an arrow pointing down to 3rd. Which is true, i could go faster in third haha
Another question for you guys well a few.
Why did you choose your monte carlo ?
What other cars were you looking at and what made you choose the monte carlo over another car ?
Thank you in advance just nice to know why other people would go for these cars.
I was also looking at the Seat Ibiza 1.2 TSI FR 5dr. Got a better deal on my Monte Tech than I could on the Ibiza, I also preferred the interior of the Monte to the FR as well.
Same engine and running gear on both cars but there's not much in it, Ibiza was £30 Road Tax where as the Fabia is £110 but I got 3 years free servicing so it works out cheaper, slightly better spec on the Ibiza but there's not as much space as there is in the Fabia.
Yes i get what you mean the fabia looks so much better just a shame that the tax isnt £30 but on the other hand you can now pay for tax monthly now cant you ?
So is the FR the same speed as the monte carlo 1.2 105 ?
Just about, I think the official figures have the Ibiza's 0-60 time slightly quicker but there's nothing in it and we know Skoda are conservative when quoting performance figures.
It comes down to personal preference at the end of the day, I probably would've chose the Ibiza had they matched Skoda's offer but I went for the best deal. I don't regret buying the Monte, I love it and I'm looking at replacing it with a Fabia III estate when the deals start.
That's great staying in the skoda family ha the Monte Carlo just seems to tick all the boxes for me and you guys have helped me decide the the monte is the one for me
