12V socket connection
Is it only mine or all Fabia's 12V socket (cigarette lighter) are powered all the time, not only when the key is in the ignition ? Is there any way to change that ?
Mine is too. Could be done, I would suggest cutting off the live cable and insulating it, then run a new feed from the fuse box (use an "add a circuit" from the rear wiper fuse with a 10A fuse) and join this to the cigarette lighter socket
Hope this helps :)
Or put a switch on the line.
  • 4 months later...
I did that, put the switch where the old lighter was and put the lighters (added an extra one - with inline fuses) under the heater controls - can still open the ash tray (not that I use it) using an extra radio din thingy bit I had laying about
oh and they light up when the lights come on, the switch only lights up when on
Edited by SkUG
