DRLs using Fogs
Used vcds which easily let me choose to activate fogs as DRLs and it worked. Trouble is they will not switch on/off from the indicator stalk as per the manual. (Don't have maxidot)
Wondering if I need to activate another option as well.
Couple to choose from i.e. Activate DRL via seperate lights,
or DRL adaption active (MFA +) (Not sure what this is. Did a search and wondering if its something to do with the Maxidot menu so that wouldn't apply to me)
Sure someone will have the answer.
Thanks guys
Edited by maverick54
  • 2 months later...
If your FL Octavia has front fog lights it will also have the seperate / dedicated DRL's too.
Just curious in this case why you need to use the front fog lights as DRL's?
 This option will turn on the dedicated DRL's.
