Steelies....exposed or trims?
Never used winter tyres with steelies before but fitted a set on the vrs at the weekend
I don't mind the way they look,they give a vague idea of what the car would look like with black wheels
From a security angle (exposed wheel nuts) plus they are open to the elements is it worth putting wheel trims on ?
I was looking at these....
http://m.ebay.co.uk/itm/251263145463?nav=SEARCH
What have you guys done,covered them or not?
I wouldnt bother. Personally.
So when the alloys are on, the wheel nuts aren't exposed then? :ph34r:   Personally I'd leave them without wheel trims off, too much of a ball ache, if need to change a tyre etc.
Compatability chart says they don't fit Fabia
Fitted Fabia official trims last year and they were such a sweat to fit ( & cable-tie ) that I didn't bother this year.
Mrs puny hates that, which is another plus for leaving them off.
Correct but on an alloy they have the caps on and are inside a surround on the wheel centre
As they are now they look very exposed
As for fitment ,on the eBay app it says Fabia 2011 - all....but if they're ok in the elements I'll probably leave it
Guest
