New Beeeeee needs help Evap code! any idea and engine light on!
Hi all
I have a Engine light on in my 2006 vrs, The code is something to do with the Evap system? if I'm reading it right. I have looked on Google but total confused, any one had this problem before?
On the plus side the car drives great no boost issues or lose in power
Edited by mitman1982
If the code is P0441 - Try replacing your N80 valve first.
Mine had the same problem and code; this solved it.
Thanks buddy will do, there loud engines was shocked to find out its normal very clicky and top load! With the bonnet up
Might just have been overfilling. Does it go out after a bit?
Mine did it a couple of time when I'd filled the tank past the first click of the pump. Went away after a bit.
TFSI doesn't sound great. Cracking engine but the noise isn't one of it's best features.
Edited by Aspman
Sounds like the charcoal cannister had same problem a while back, changed valve no change cost 35 pounds from dealer cannister was 81 pounds and all fine now.
Charcoal dries out in the cannister hence the fault, i should have taken advice from other members who had same, and saved some cash. Its located front left corner near washer bottle.
Thanks guys realky helpfuly
Where did you get the charcoal canniest from bud
Got from dealer in york where i live, certain parts are best dealer parts this is one of them. Your looking around 30 second hand and dont know how long it will last.
One thing you will find you have to use your own bracket , as new one comes without easy to do.2 x 10mm bolts and a 10mm nut.
Cheers mate will put the code reader back on tomorrow and have a look buddy! Just looked at the charcoal cannister and the pipe just came of in my heads so glued it back for now! Will get a new one tomorrow and a new N80 and go from there
Thanks guys
