Difference between Amundsen and Amundsen+?
If someone can tell me the difference and benefit of the + over the normal one then that would be greatly appreciated. Also do they both come with Bluetooth?
Thank you
I belive the + has DAB
Sent from my Galaxy S5
The one fitted to post 2012 Rapid/Toledo has DAB, Nav, Park display, Bluetooth, cellphone integration, BUT no speed cameras or any option to add them.
So if thats important to you get Columbus instead, it can have a camera database added. I'm stuck with factory Amundsen with my phone stuck on the dash on speedcam duty - and while it does that, I cant bluetooth to the car either - or my camera warnings are muted!!!
See here for factory nav systems that can or cant be enhanced
http://www.pocketgpsworld.com/modules.php?name=Cameras#compatibility
Edited by camelspyyder
Amundsen maps are stored on an SD card whereas Amundsen+ maps are stored on the built in hard drive freeing up the SD card slot.
Amundsen+ can be had with or without DAB so don't be fooled into thinking every + has it.
Bluetooth on my Monte Tech has a module fitted under the back seat so I don't think it comes built in to the unit itself.
As above my + doesn't have dab or Bluetooth however both can be added
The satnav data is on the hard drive and not the sd /cd hence you can have the sd slot free to use
Thanks guys, yeah found out it doesn't have dab which i really wanted. How do i go about adding bluetooth? Is it costly and hard to do or?
If you can get a Bluetooth module from FleaBay or somewhere like that then it'll just need coding via VCDS, I'm sure it's been done on here.
DAB can't be retrofitted to the head unit but you can get DAB receivers that would work in conjunction with the head unit though.
Edited by Gazbull17
I have the + and the only think i dont have is DAB ive even bought an reciver & plugged it into the back of the headunit and still it dont pick it up and links to what will work? Or has anyones made it do able to have dab in there car?
Im a girl so as much detail as poss is appricated :)
Thank you
I've just removed the factory fit Amundsen Plus out of my Octavia SE Plus and replaced it with a Columbus. I can't comment on its long term use as it was taken out within 24 hours of picking the car up, but can say for certain that the sat nav part appears very user UNfriendly compared to the Columbus with horrible graphics and a small screen.
However, the Amundsen Plus did not have DAB. but did have inbuilt bluetooth, and I had to install a separate bluetooth module when fitting the Columbus.
Mike
Hi Mike. Are you selling your Bluetooth Amundsen as I am looking for one
Don't worry I've just seen you removed it from and octy... That'll not fit in my fabia
  • 6 years later...
does amundsen+ work with factory bt module?
does skip to next song buttons on steering wheel when playing music trough bluetooth (avrcp) work with amundsen+?
Mine does when using say Spotify.....................but has built in bluetooth
PS there is posts above that say the Amundsen cannot have built in bluetooth, it most certainly can have that and then there is no need for the additional module.
Edited by UrbanPanzer
amundsen+ can have bt built in, now question is if avrcp will work with unit without BT and external BT module, or if I can get unit with BT and not use bt module and everything will work, maybe just rewire the mic?
I also noticed there is input for two video feeds, is there some reasonably easy way to trigger front camera when parking and shifting from R to D? Or would need to coble something with timer relay etc.?
