One shot electric window setting
After fitting a new battery last week the one shot window option is not working on my fabia front electric windows.
Please can anyone tell me if there is a VCDS adjustment possible to bring this option back again in a Fabia 1.
Thanks in advance for any replies
Close the window to the fully up position. Pull and hold the window switch into the up position again, you should hear a small click from the motor.
One touch is now set for that window.
This ^, you have to do it for both windows separately
You may have to do the same with the windows down in order to 'tell' the car where the lowest position is.
The correct way is make sure the window is closed all the way. Then put the window all the way down, then all the way back up again.
It has to re-learn the down/up positions again.
Phil
Sorry for not replying my internet has been down
Thanks to everyone for the information
  • 2 months later...
I can't get mine to work again. Nothing I do will reset them to auto!
Ps I used the key in the door method to get them to work
