Skoda Octavia FL 2010 - Broken rear ashtray
Hello everyone!
How many of your beloved cars were "brutally beaten" by feet / shoes / boots children, that when you try to sit in the chair and just see later, a brutal image of ashtray "fractured" and without arrangement?
I have one of these cars "victims" of this aggression where the harasser is a little eyes that say "Daddy, it was not me !!!" : shock:
Finally, we live with this illness!
But today, I decided to take the car from the garage and takes it to the "the operating theater", located on the doorstep and with a brutal desire to take by force the "nemesis" in "coma"!
And I got it!
This is the way that i found to repair the back ashtray of my Octavia FL 2010, broken by my son...
1º - Pull this part of (hard if need it!).
2º - With a small screwdriver push the ashtray module to get it out!
3º - The module off the socket, get out the lamp. Is possible to see the damage...
4 - Module extrated.. :twisted:, Need to extract the dust-cover. You must take care not to break the fittings !Well see the pictures! :shock:
5 - With a sharp object is necessary to push the steel left to right.Attention,The spring that is closing the drawer is to push the wire that holds the cover, long-nose pliers to pull is required..
6 - This is the spring.
7 -the stud broken (I will have to make a hole and put a pin in metal ...)
8 - The hole destroyed, I have to rebuild, do not know how.
This small fitting (under the cogwheel, arrow-headed)was also forced by the weight of my son. Is bent, you need to force it but without breaking it!
9 - In this photo we can see the twist of "arrow", live is best seen...
Repair of the ash drawer:
Condition:
Broken... :(
1 - Smoothed fitting party with a grinder so you can drilling all right
2si0ayrby7afqc47g.jpg.
2 - I made a pit in the exact place of the hole into the place to be as straight-laced as possible
3 - Stuck with a drill of 2.5 mm thickness of the stud broken.
4 -The same drill, cut the part where tightens the machine (see previous image), enough to enter the hole and out the same length, same as the other side of the ashtray. Thus the pin is exactly the hole diameter and fits perfectly. The drill, I had to cut with rebarbadeira (machine-tools), the saw cut iron was useless ... :mrgreen:
After cutting, place a few drops of Super Glue to secure the pin.
5 - These were the tools I used to pin repair.
With ideas without using glue. Tip of my co-worker, Eng Paulo Vermelho! :mrgreen:
Repair of the drawer fitting
1º
With a drill to make one or two holes in the ashtray back to do a bit of plastic that will serve as the glue / filling.
2º
The plastic to be used. :mrgreen:
3º
With a soldering iron, melt the plastic to make filling (which was done with the drill) with a soldering iron (melt, not burn!), A little melting the hole with the shaft in place (so that the weld is possible ) but do not deform the hole and rotating so that the plastic does not "snap" iron. Do not leave too much plastic as a filler because it has very, will not fit between the lid and the ashtray! :shock:
(WARNING: MELT PLASTIC WITH THIS CAME IN PLACE [/ u], OTHERWISE THE HOLE WILL DEFORM AND GO FOR ALL "HELL" !!!)
4º
Work after melting plastic...
5º
As I have a rectifier, put a small emery and I perfected the fittings. can be done with a file or a nail file.  :mrgreen:
6º
I mounted ashtray. It has to be without cover, because with this you can not remove or put the shaft! Do not forget to put the spring that makes opening the cover !!!
12
Fixed ashtray!!!
And so I find complete this repair, which victimizes many owners Octavias and that small "Terrorists" Psychological try again destroy the ashtray for the second time ...
We will see the excuse that will give...
Best regards.
(NOTE: WHO NEED HELP THAT SEND PM.) :mrgreen:
From Portugal,
Sergiobbessa
Sorry for my English!
