Vrs still leaning to the left
The previous owner of my car fitted some AP coilovers and I noticed the car was leaning to the left.
I recently raised the car as it was also way too low and made sure that the suspension was set at exactly the same height as to correct the lean on the car. Both rears were set the same and both fronts were set the same.
However it's still leaning. The passenger rear is 20mm lower than the drivers rear and the passenger front is 10mm higher than the drivers front. I double checked and made sure the springs were set at exactly the same height, so what's the problem?
Any suggestions guys?
Tbh mate i thought I was reading my own post. Mine is on coilovers n veers to the left a bit. I'm putting it down to duff top mounts, bumpstops and wishbone bushes. The wishbone bush is load bearing so if it's put in the wrong way or is on its way out, it tends to have the car leaning and causing the car to pull to that side.
Cheers pal, I'll look into the wishbone bush.
