cam belt changing 1.9D Without special tools
If you're changing your cam belt on 1.9 diesel you You don't need a specialized locking kit you have everything you need in your toolbox.
6 mm drill will lock the fuel pump
16mm spanner will lock the cam
And a modified angle grinder spanner will adjust the tensioner
You can use right angle circllip pliers for timing belt tensioner. Thats what I did when I changed mine a few weeks ago.
No one mentioned a great big hammer?
