electrical fault!
Hello, when i remove my key from the ignition after driving, the interior light sometimes doesnt come on straight away. most of the time it comes on as soon as the key is removed. is this likely to be an earthing fault? Or a dodgey wire? My headunit is also playing up but i don't know if they are related yet
cheers
S-contact on the back of the ignition switch sticking most likely, it is an electric contact that controls the switch live to the stereo amd a few other things
That would make sense, how easy is this to fix? Just a case of taking some plastic off and cleaning up the contact?
Not sure on a way to fix, but try googling vw s-contact repair
Ok thanks very much!
Try some electrical contact cleaner first.
I had a look but couldn't find out how people had sorted it, one person said a tiny bit of wd40 in the barrel but im unsure on this
Have you seen the youtube vid of the VW ignition switch teardown?
I havent no but i will have a look when i can, cheers
