Bolero coding issues dtc's appeared not clearing?
Hi all i have an 06 pre face vrs have installed a bolero, and an updated can gateway, 'Q'  the gateway came from a seat but same part no..
got round to coding gateway checked every option that was ticked on the old gateway.
plugged in new gateway everything i needed in the installation list was already ticked. so just went into long coding and changed the car to skoda and style to sedan...
I then went into auto scan cleared all the codes, there were a few codes which wont clear. there are five engine ones and a radio one.
any help will be appreciated..
 Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1Z0 907 115 A    HW: 1Z0 907 115
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H10---    Serial number: SKZ7Z0E3354377
   Coding: 0203000318070060
   Shop #: WSC 28059 576 91019
   VCID: 3365F94752C0B386591-8066
5 Faults Found:
049493 - No Communication with Instrument Cluster
               U0155 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 31.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.319 V
049472 - Body Control Module (Central Electric)
               U0140 - 008 - No Communications - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 31.0°C
                    Temperature: 29.0°C
                    Voltage: 12.319 V
049478 - No Communication with Diagnostic Gateway
               U0146 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 31.0°C
                    Temperature: 29.0°C
                    Voltage: 12.319 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 31.0°C
                    Temperature: 29.0°C
                    Voltage: 12.319 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 31.0°C
                    Temperature: 29.0°C
                    Voltage: 12.319 V
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8174950
   Coding: 050004000001
   Shop #: WSC 73430 790 00000
   VCID: 3561C75F9CB4ADB6775-8060
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 103266 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:08:33
I had the same code for the radio - 01044 - control module incorrectly coded.
Go into the long coding and change it from 050004000001 to 020004000001, clear the code and it shouldn't come back (at least this worked for me).
As for the engine ones, I'm not really sure. They all relate to intermittent comms, I'd check the wiring and that all the connectors are tight to the can gateway and at the back of the bolero. Probably also worth checking the CAN gateway coding again.
Hope this helps,
Alexander
Cheers will try the coding change and report back
Looks like the newer revision CAN gateway isn't communicating with other CANBUS system modules properly, from looking at those codes.
As already said, I'd go back to basics and check the connection to the gateway - maybe even put the original gateway back in and re-scan again. Could help you pinpoint the issue.
Cheers got rid of the engine codes by going into the controller rather than doing a full scan just radio now.. I've tried changing the code and saving but when I go back in it hasn't saved it's the same as it was originally.?
Which version of VCDS are you using? For Radio, should be a case of tweaking the coding, applying and you'll get a dialogue box confirming changes have been made.
I usually then exit that module, return to the VCDS main page, then log into the module again, and double-check the coding.
