ASR switch + TPMS
I've got, very confused now with attempting to wire in the TPMS switch, to a point i've lost the original colour/wiring order into the original ASR switch.
can someone grab a photo or does anyone have a list of the correct wiring for pins 1-6?
1 ?
2 ?
3 ?
4 ?
5 ?
6 - Brown
thanks mike :)
Mike I think I sent you my write up didnt I for your retrofit list? I can't find it anymore on my PC for some reason but it might have had this info.
Yes you are right Mike, it is ESP.
Brilliant, thanks!
Will leave wiring it back up till after the new ABS pump is installed.
Gonna be an expensive week, Camshaft chain tensioner replacement, ABS pump swap.  yay.
Okay,
So, when a fuse is blown, you should pay attention to where you put fixed fuses back :|  ABS controller now working :D
