mk1 octavia vrs stage 2 tuning Please Help!
Hi i am planning to tune my car. I would appreciate if anyone could point out any parts i have missed out or to be corrected in the list below. Thanks Guys.
fmic
cai
sai delete
ko3s hybrid
tip
maf?
440cc injectors
4 bar fpr
255lph fuel pump
3 inch decat downpipe
mid section pipe??
cat back
n75 upgrade?
uprated diff
g60 flywheel
vr6 clutch
Also when i change gear the revs seem to hold. Is this a safety feature and can it be mapped to remove this?
I have already had a stage 1 map with a k and n panel filter by Jabba. I intend to go back there once myself and a mechanic friend fit these parts.
I had the same problem with the revs holiding between gears. Turned out it was an "Implausible signal" from the clutch pedal switch. Very quickly swapped the switch for a new one and all was well again.
Incidentally Jabbasport did my IHI VF34 kit for me......some 80k miles ago and it's still going strong and I use the car every day. SAI and N75 and Recirc Valve still standard. Exhaust is a resonated 3" Milltek all the way through from front to back, from a Jabba exhaust manifold.
Good luck with the build.
OK thanks. Are the parts I stated on the right track though?
The parts are on the right track, but have you thought about the handling by upgradeing the bushes and suspension?
Hi I am thinking of coilovers, uprated Arbs and s3/TT strut braces
The biggest difference to the handling on my car was when the RARB went on. It almost completely eliminated the understeer. I couldn't live without my Quaife LSD now either. The Weitec coilovers are another matter though. They're well choppy. Great for lovely smooth roads, but a bit of an own goal considering how lumpy it is out here in the fens.......doh!!! :dull:
