HID 35W h7 6000k kit from London colour
Bought just over a month ago now. Perfect working order. £20 Delivered
I have this same kit, very good and well worth the money!
Do these have a positive/negative lead that has to put on battery etc
No they don't.
So there literally just plug and play with no messing about connecting leads to an earth and battery positive?
Yep, I have exactly the same kit on my Octavia. Fitted them in like 20 mins took me longer to remove the headlights!
Yeah you just use the existing plug on the headlight Danknott. One thing to note is its reverse polarity so the blue lead goes into the live and red into negative.
Price reduced to £15 delivered
Will these fit straight into my mk2 pre fl vrs?
Yeah there's no additional wiring required
Ok mate just checking they hadnt been butchered to fit something else, PM me your paypal address ill have them cheers
Payment sent with delivery details cheers mate
Just make sure you code them via vcds as the last thing you won't it to blow you ccm / bcm / wiper motor
Sold
Do these need coding in then ?
Do these need coding in mate ?
They need coding to avoid the bulb warning light and them possibly switching off/flashing.
Phil
Phil
Cheers for the info mate, it was stated these were plug and play !
That's easy takes a few mins, loads of members with VCDS on the map :)
Yeah cheers man, i just thought they had resistor or something else as part of the kit to sort that out, its not a problem, just thought i could fit and forget ! My local indy will prob be able to code them in for me
Yeah mate. Sorry I thought you may have known. Are you still wanting them or would you prefer a refund?
Did the previous sale fall threw due to coding as I'm more then happy to take them for £15 delivered let me know either way thanks
I've not yet had a reply Daniel
Ok mate soon as you do just give me a inbox either way to let me know thanks
