fun front disk upgrade
is there a straight swap out there...
one which needs no or little modifications or fabrications..
(as it would be done on my drive way, and i have not much access to fabrication gear)
i am fairly competent with a set of spanners
and mostly.......... will it make a noticeable difference
thanks fellas.....Keith
You can upgrade to 256mm, 280mm and even 300mm discs.
256mm being the easiest and a damn good upgrade on a felicia! The other two would be abit OTT unless running good power.
Take a look in the classic technical guides there is a thread for the 256mm upgrade.
thank you Tom...... will check it out...
it was noted on last MOT that the pads were low and disks were pitted and scored, so it i have to change them, i may aswell upgrade the whole thing..
so it will be fine with 15 inch wheels too
thank you......... Keith
hi Tom... sorry to be a pain.. i have just looked at front disks, but am un-sure which will fit.. the 2 links below seem to have different hub depths... could you please let me know which specific disks i will need  (make model year etc)
thank you very much......... Keith
http://www.ebay.co.uk/itm/2X-VW-Polo-2001-2009-VENTED-front-brake-disc-PAIR-256MM-/150945885412?pt=LH_DefaultDomain_3&fits=Car+Make%3AVW&hash=item2325136ce4
http://www.ebay.co.uk/itm/One-Pair-Of-Quality-256mm-Front-Vented-5-Hole-Brake-Discs-/361039534138?pt=LH_DefaultDomain_3&fits=Car+Make%3AVW&hash=item540fa2183a
Neither of those discs are correct.
You need 256mm discs from a kia rio mk2.
http://www.eurocarparts.com/mobile/ecp/c/Kia_Rio_1.5_2005/p/car-parts/brakes/brake-friction/brake-disc/?104900298&1&3dbd568f9acbd1538494845a98f721574d15e690&000027
Edited by nu99et18
