gtb2260 turbo
as above where can i get the 3 bolts to bolt down pipe to turbo? any links plzzz?
None in your nuts & bolts draw? :D
I am sure my kit came with the necessary bolts.  Meant I had no shopping around to do,
Surely you can find or buy M10 bolts, nuts and lock washers, it's not like they're anything special, just vanilla mild steel will do, even Hellbase/B&Q/Halfrauds sell them.
Usually studs and nuts on all the GTB's I've seen.
No studs fitted when it arrived?
Thinking about it you might struggle to get a bolt in the hole behind the down pipe,so you will need studs and nuts+it makes it easier getting the downpipe on if you've got studs in turbo.
any1 got a link to the studs needed
m8 x 20
Not looked at available lengths,but would guesstimate 30mm,20mm for dp flange and nut,10mm screwed into turbo?
Are you using a 3" downpipe if so remove the stud from the exhaust that nearest the block and use a 25mm bolt Allen key fitment cut 3mm of thread off it and fit that instead
You will find you can't get a spanner in to do up the nut
On the other 2 stud cut them down so there is just enough room to fit vw style nuts 12mm you have to go round them doing them all up 2 turns at time
