Just passed 100k so time for suspension upgrade
I know which setup I want which is this :
http://www.demon-tweeks.co.uk/performance/suspension-kits/car/skoda/fabia-00-07-vrs/2004/1-9td-130/eibach-b12-pro-kit-suspension-kit-with-bilstein-b8-dampers-lowers-front-25mm-and-rear-25mm
Not clued up on places to buy so would like advice if it can be had any cheaper elsewhere ?
I have just purchased some 17" Spiders and 205/40/17 tyres and am assuming they would be ok with the above setup ?
Last but not least ,what else do you recommend me replacing whilst the garage is fitting the suspension ?
Any links would be great as like I said I'm clueless when it comes to parts and online suppliers
Thanks in advance , Peter
Spiders will be fine on a 25mm drop. Personally if you're spending on a decent suspension kit then I'd replace everything perishable while your at it. So bushes (as a minimum the wishbone console ones), drop links, anti-roll bar, ball joints, top mounts etc.
Have a look at the AP kits, they are said to be very good value but you do get what you pay for. The Eibach and B12 kit is about the best spring/shock kit you can get, you'd have to spent a lot more to get better.
That's a very good price for the B12 kit, Koni or Bilstein adjustables are much more expensive.
