Light failure warning
Hi guys. Got a Mk1 Octavia estate L&K. In the last week I've started getting a light failure warning on the dash, usually when I brake. I have checked and double checked several times all the lights on the car are working. Any ideas?
Could be the Brake pedal switch failing.
Did you check that it is not a brake light bulb that has failed?
Ah yes! I changed that switch a few years ago. I will have a look at that. Cheers.
Yes all the break lights are operational.
