Which Vag Com setting to use of MK1 VRS
Ive managed to source Vag Com/ VCDS to sort my throttle body allignment, and found a guide on Ross Tech.
Does any one know though a MK1 1.8T VRs if its
1. Cable Throttle
2. Drive By Wire Engines using KW 1281
3. Drive By Wire Engines using KWP 2000 or CAN
4. Drive By Wire Engines using KWP 7000 (UDS+ODX)
Depending on which my car is, the procedure is slightly different
Yours will be DBW so group 060
Thanks David :)
