sytec help
ANYONE GOT A LINK OR THE HOW TO ON FITTING A SYTEC PUMP the cheap euro one i had to put in when my old oe pump died has lasted 24 hours before playing up quality part eh
any help links etc be great
will the cupra r 4 bar pump go straight in the tank as have one at home i took out of a breaker i did?????
ANYONE?
If its an early single outlet pump then yes
If its a later twin outlet pump you'll need to make a pipe to return the 2nd outlet to the bottom of the tank
-unless you've got the later swirlpot too which has the 2nd outlet pipe built in
Edited by snow_muncher
Was a brand new pierburg 4 bar looked identical to my old one , there all same length etc but can defo hear 4 bar pump working over the old 3 bar one
