Alloy Wheel Center Caps corroding :(
Is it worth, while they are newish and still okay, taking them off and spraying them with several coats of clear gloss lacquer?
Got round it, bought new wheels. ;)
Don't! only warranty item for 6 months (see my thread above about external trim warranty...centre caps in my case too
My dealer replaced mine at 14 months due to corrosion no questions asked
Had all 4 of mine replaced today along with an alloy that had a bit of water ingress on the polished part. Car is 20 months / 24k. All done without an eyelid even being raised.
I was thinking the same thing.  I'm not sure if the lacquer might react with either the existing PU coating, or the aluminium we are trying to protect.  Trying for a warranty replacement might be a better idea.
Apart from the wet I think the salt put on winter roads doesn't help either.
2 winters ago I bought a set of new Octavia alloys from a bloke in Austria off eBay.
They came with a set of hub covers too. I used one set for winter and my original ones for the summer months.
The summer ones are fine the winter ones look much worse for wear.
I have since obtained another set and have done what was suggested, three or four good coats of automotive clear lacquer on them.
I have also done the same on the center caps on my aftermarket alloys which I currently have fitted, early days but all holding up well.
