Fabia vrs, negative camber on n/s front?
I have an issue with negative camber on the n/s front, I've managed to sort it out a little bit by moving the bottom ball joint and top mount position, but is still not perfect.
Is there anything else I can do?    Cheers Craig.
How do you know there is negative camber?
Are you certain that none of the suspension components are damaged?
SN
Tolerances in a couple of fittings can influence it.
 - Consoles mounting onto the subframe.
 - Subframe mounting onto the car.
With the age of these cars it's probably better to do this with full support.... i.e Not on a driveway on a Sunday but in a working garage services in the week.
J
I had that when I had coilovers. I put my standard suspension back on as I couldn't sort it and it was wearing out a tyre a month
