Ebay CAI
fitted mine tonight... The brackets were not quite in the right position and angle so had to modify it a bit to fit.
Before I had just a panel replacement filter on my car. That had improved things no end, slightly better noise and much much better after 4.5k revs, flew up to the red line so much better than before.
This has increased the noise a fair bit, the dv is much more noticable at all speeds, and there is definately more induction noise, you can hear it really sucking in the air. I have only done about 5 miles with the new one in so didnt have enough time to warm the car and test it properly, but there seems to be a slight improvement in speend, but nothing like the jump from the panel filter...
hope that helps a bit, will come back if I change my mind after more miles...
