Stuttering on moving off,
2011 1.6 Octavia.
 After sitting for a while eating an ice cream , when I moved off there was a small thump/backfire and stutter which cleared and went ok after.
 Just for curiosity  scanned it and got the following :-
address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8810
   Revision: --H43---    Serial number:
Coding: 00114016032500080000
   Shop #: WSC 73430 031 00074
   ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
   ROD: EV_ECM16TDI02103L906023LP.rod
   VCID: 7F0DE78DE62FC0D917A-802A
1 Fault Found:
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [032] - Signal too High
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 28481 km
                    Date: 2015.03.04
                    Time: 16:47:46
Readiness: 0000 0000
Its the         " Intermittent - Not Confirmed - Tested Since Memory Clear"  I'm wondering about.
 The other codes were:-
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 48000AB8A05BB1C04010008011000124430000AE726D81605C8440000040
   Shop #: WSC 73430 790 00074
   VCID: 3F8DA78DAEAF00D957A-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 12101  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 171111 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
2 Faults Found:
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 161
                    Mileage: 27588 km
                    Time Indication: 0
                    Date: 2015.02.21
                    Time: 09:25:25
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.15 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
01134 - Alarm Horn (H12)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 196
                    Mileage: 28898 km
                    Time Indication: 0
                    Date: 2015.03.14
                    Time: 10:30:19
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.05 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
I cleared the codes then rescanned and everything was clear.
But when looking at the laptop the engine started hunting when idling as if running out of fuel . revved it up and it did it again , revving up second time it cleared and idled normally .
Rescanned to see what caused that there were no codes showing .
I  scanned it about a month ago and there were no codes apart from this which has now disappeared.:-
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 171111F2000992
   Coding: 351303
   VCID: 3A7BD699B58D25F161F-806F
1 Fault Found:
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 137
                    Mileage: 20987 km
                    Time Indication: 0
                    Date: 2014.09.22
                    Time: 08:29:39
Anyone any ideas?
