Changing Seat belt stalk on o/s front
i need to change the seatbelt stalk. I've read on another post that the 2 trims need to come off and undo the two bolts at front of seat. When seat pulled back fully.
But I'm wondering do I need to disconnect battery for srs system. Side impact Air bags etc.
Are the lightly to go off when moving the seat around or will it be safe to do with out disconnecting.
Thanks. Steve h
Always better to be safe than sorry.
Does anybody have any views or experience with removing front seats with air bags in
Disconnect the battery. You will also probably find the bolt holding the buckle is a triple square (XZN) one.
Sent from my HTC Vision using Tapatalk 2
That's the spline type ? If it is I need to get one
Yes a spline but not torx.
Yeah I got torx. But not the others.
Thanks guys I bought some splines and job done in under 20 mins.
Disconnected battery and all ok.
