Mk 1 Fabia: AP coilovers; Mk2 Octy: Team Dynamics ProRace 1.2 with Eagle F1s
Few bits for sale.  Pictures to follow. In Sheffield
mk 1 Fabia:
Jetex Cone Filter / kit. Includes 45 degree silicone hose plus 3 jubilee clips, plus 95degree bend insert to connect the vacuum hose that goes to airbox. So complete kit to replace standard air box. One slight bit of damage to filter where it rubbed against a zip tie. I ran it with the damaged area covered with a little bit of gaffa tape and on the bottom out of sight. £40
AP coilovers. In perfect working order and adjusters move freely. With Ibiza Cupra rear bump stops and couple of month old shortened drop links £250.
mk2 Octavia:
Brand new Climatronic panel for heated seats 3TO 907 044 BS  £70 posted
H&R Comfort Cup Kit.  Working perfect. £250.
Vanstyle w0ndow blinds for FL estate:all rear windows and boot window.  £45
Team Dynamics Pro Race 1.2s 17 x 8, et 45. Perfect stance on a mk2 Octavia. Hyper silver and excellent condition: only a couple of minor marks. Come with Goodyear Eagle F1 AS2s.  2 with approx 5.5mm tread, 2 with 3.5. Give a bit more comfort and save about 4lbs per wheel over Neptunes! £550  Pics in post below
Superpro Anti Lift Kit. Bush pressed into console housing. £120 posted
Dave
Hi, any pics of the rear blinds please thanks.
RCB: Will get some done for you tomorrow
mk2 Octavia:
Hi, I might be interested in the suspension if it fits my 2.0 tdi pd nonVRS
So, is it for VRS or nonVRS (50 or 55mm)? How old are they and how many miles you've done on them? Some picures would be great too.
Hi,
Mk1 AP coilovers - can you send me some pics I'm interested.
Minty
Would love to see the window blinds :)
If no one else takes the coilovers i might be interested. how old are they?
H&R:
Bought by me from another forum member with 8k on them.  Think he'd not declared to insurance  so had removed stickers for stealth look! There were 2 shallow chips to coating in upper rear shafts when I received them: not sure what caused these.  I filled these with a 2 part epoxy resin (lots of experience doing this to MTB suspension after rock strikes).  I've since done about 18k on them.  No change to filled parts (which are underneath bump stops and don't contact shock seals anyway).
They should be perfect on your PD, they are the diesel kit fitted to my cr170.  Comfort Kit (not the lower drop Sport Kit) Give 35mm drop on a standard car, 20mm on a vRS (already 15mm lower than standard).
Pics below including drop on my vRS with 17s.
AP coilovers. Rears still on the car, and my wife has taken the car today with the fronts in the boot, so no current pics, but here is a picture when I had the fronts off (for new top mounts- not included) a few weeks ago.
Approx 2 years old.
Superpro ALK. Comes with special superpro fitting grease. Makes a huge difference to handling. Point and shoot with it on!
Vanstyle blinds photos: to fit FL mk2 Octavia estate. Perfect condition with all fittings. 'marks' on photos are just where the material is touching the floor.
Wheel pictures, including close up of the only real but of kerbing, also back to front picture showing offset. I think offset is perfect and saves a lot of money and worries in spacers.
how many miles has the alk done bud?
I'd say about 10K.  Bush looks as new.
Deposit taken on AP coilovers.
I'd offer £100 for the alk.
Regards
Simon
Balls I would have taken them blinds but mines not a estate :(
PM'd
Had a question over the condition of the H&Rs which were a bit dirty in the picture so cleaned one of the front struts up and a couple more pictures.
And unless anyone knows otherwise I think the window blinds do fit FL and pre-FL mk2s.
Induction kit, ALK, coilovers all SOLD
Coilovers back up for sale.  Just them, climatronic, and the Pro Race left.
Bumpety bump
  • 4 weeks later...
Are the coil overs up for sale still ?
Sorry only just seen this .  Yes still for sale
