001027 - EGR Valve (N18) P0403 - 000 - Malfunction
Hi, I have a Fabie greenline -10 that have done 110k miles (18.000km).
My egine light and came on so I ran a VCDS scan and got the following.
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 045 906 013 AJ    HW: 045 906 013 AF
   Component: R3 1,4L EDC G000SG  4635
   Revision: --H04---    Serial number: SKZ7Z0I5580409
   Coding: 0003071
   Shop #: WSC 13765 000 00000
   VCID: 5785B7F9E59030997F5-FFFF
2 Faults Found:
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 4.0 km/h
                    Load: 0.0 %
                    Lambda: -6.4 %
                    Mass Air / Rev.: 265.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Torque: 36.0 Nm
               P0403 - 000 - Malfunction - Intermittent - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 4.0 km/h
                    Load: 0.0 %
                    Lambda: -6.4 %
                    Torque: 36.0 Nm
Readiness: 1 1 0 0 0
My qestion is if its a mecanical problem so I need to change the EGR or if it might be cloged so a cleaning with some cleaning spray (what is recomended? Bardahl EGR valve cleaning kit??) could do the trick?
/KG
How easy is it to get at on the Greenline?  If it's an easy out job, I would clean it to see how it goes - if it's a pig out job then I would change it...
Is the light still on at restart?
Dont know yet, some say the engine needs to be lifted.... Some say it might be possible to change it without but its a pain in the .... Thats why I was thinking of doing a "spray cleaning" first. But dont know if its a mecanical or clogging problem...
