Boost pressure - Fabia mkII vRS
Does anybody know where I can find actual/requested boost pressures running VCDS on a Fabia mkII? When selecting "Engine",  the Measurement Blocks field is disabled and only Advanced Measurement is accessible. Is Boost Pressure found there? Had a look yesterday but couldn't find anything related.
Yes, it is, there is a few positions under different names showing intake pressure from different sensors. I cannot remebere from the top of my head but it is there
hi, have a look here:
http://www.ross-tech.com/vag-com/tour/m-blocks.html
Boost pressure is measurable from a separate "turbo" option apparently, although I've never tried it myself
HTH
Measuring blocks seems to be disabled for some reason.
You mean it's under "Advanced meas. values" Jabo? Maybe I should look for "intake pressure" rather than the word "boost" that I had in mind.
Yes, under AMV's. I was using "Absolute Intake Pressure" in kPA but there is at least two or three others to choose from. I would have to play around with them some more.
