Horn not working?
Horn doesn't work on my fabia. I've checked the fuses and they're OK.
Where should I start looking.
Unplug it, get a test light, put it to the wire and get some to press the horn. It should light up if everything on the wiring and fuses is ok.
Then replace the horn.
Or I suppose for the price just get s new horn, plug it in and try it, if not return it.
I had same prob
The horn should work of both sides of steering wheel. My fuse was ok. So took horn off from under front bumper passenger side.
Turns out water had got into it. So brought a lownote (think thats what it called) horn. But as the new horn wasnt direct pulg in.had snip wire and use diff joiners. It works but only off right side of steering wheel
Havent got round to cleaning contacts back of wheel. I did thread on this months ago
