Injector resistance - VCDS
Hi all,
Is there anyway you can check or test an injector via VCDS?
I have the full version of VAG COM and just wondered if there was a way to test a dodgy injector to see if it was faulty or its simply muck inside.
Thanks in advance.
What injectors, if it's tdi you can check the resistance.
The book figure of the top of my head is 0.05 ohms but double check that.
No way of checking pd injectors with vag com, oscilloscope used with a current clamp is book method of checking . They take about 20amps to operate solenoid valve with a 50% reduction in pwm once the solenoid is closed.
What are the symptoms of your problem to make you suspect an injector?
  • Sponsor
It's a petrol 3-potter. Context here.
