Ease door closure?
Is this a grease on the hinge jobby, or graphite or WD40 on the locking bits - or something else - please?
Don't want to do the wrong thing. Can't keep waking up the whole neighbourhood either :o
Thank you
Mo
:confused: 25 views and no replies?
I know it's a numpty question, but I just need to get the door to close without having to slam it. It nearly closes at the moment, then I have to lean against it forcibly to shut it properly.
Thank you
Mo
From what you're saying about it *nearly* closing, it sounds like a hinge problem to me? If it were me I'd try some grease on the hinge. It would be a trial and error issue for me; I don't think you can do too many things wrong in this situation.
Good luck :thumbup:
Steve
Thank you Wardy :thumbup:
Mo
When i first got my fabia, the rear left door was a lot harder to close than the others.
It turned ot to be the door trim was not fitted centrally, and hence catching on closure.
Might be worth getting someone to sit inside while you close it, to see if it rubs. Failing that, check your door rubber seals, as if it is catching the door rubbers will be a bit rough where it is catching.
