fabia vrs gearbox
Hi guys whats the gearbox code for the box with the longer ratio?
Drop Skoda Saint a message, he's just fitted one so will remember
cant find him in the members list??
I think it's FSM FJW for the longer ratios. Definitely start with F
Skoda_Saint even
1800rpm in my car, :thumbup:
I never got out of 4th gear around Combe.  5000rpm in 4th is about 125mph  :D
More info on here...
http://forums.tdiclub.com/showpost.php?p=3370638&postcount=26
I was considering it myself. A big part of me just wonders what the point is though, as when are you realistically going to be able to use it without risking a life threatening crash or the possibility of jail time if you're caught?...
Not to mention that the Fabia is about as aerodynamic as a brick. Not good at 150mph+ !
Sounds like you guys need the epic 1.2 petrol gearbox I'm using at the minute.
3,500 rpm is 60mph.
As per Jason's post above... it's likely out of a another car such as a Passat or Audi. Hence may have a different casing.
Best bet is to drop them a message and ask them. Although doubtful considering they clearly state it won't fit!
