Horn Swap?
Anyone ever tried swapping their Fabia horn for something else?
I fancy fitting one with a beefier sound - maybe from a MK4 golf or an Octav or Passat...
Is it easy?
I've heard you can do something where you fit a second horn to get tones?
I was goin to get a beefier horn. As mine had got water in it. I just ended up replacing mine for a low note horn. It was a different plug connection so had to cut the wire and use spade connectors.dead easy to take it out use a long extension.
Only 1 nut take the bracket off.
Do a search of youtube.seen the twinhorn on octy
