Paint matching
Can anyone recommend the easiest part to remove to get a paint match on my pre fl estate?
Towing eye cover?
I thought you had cracked it then but mine is black. The fuel filter cover seems to be attached to the inner section. My mirrors and door handles are not colour coded and I can't really see any other little bits
So your bumpers are not colour coded then?
That's a shame
That's how the guy who sprayed my previous grille got a match
That's a shame
If it was an option you can pretty much presume my car doesn't have it, or didn't at least!
The plastic trim piece under the rear light cluster either side.
These are all i can think of.
What about the information label on the boot floor or the chassis number.
Take it it doesn't have headlight washers either then? They're pretty small and easy to get off.
I have to paint a door so needs to be a good match, the bits under lights may do it if I can see where they come off. No headlight washers
