Front suspension
Hi all just a quick one ... Iv just got some St by kW shocks and springs from dpm performance (thanks dpm:) ) 25mm all round it says on the box .. Will I need different drop links aswell or will standard ones be fine ... Also while I'm at it I'm going to change the front arm rear bushes anyone running psb bushes ??? Any comments on them thanks
What spec? Vrs?
I have H&R 30mm drop springs on standard shocks fitted around 1-2k ago and didnt change drop links, but I have started to have a bit of a knock on full lock which might be them so might be worth it in the long run.
6y vrs standard ATM ... Cheers might leave standard ones on then till they go
Leave them as they are unless they need changing
Sound mate thanks and no there still fine so will stay on :)
