Front Headlight levelling sensor dangling - Info needed
Hi All,
For the first time in ages I drove my car needing the headlights on... I put them on and the Xenons were un, down, up, stay up, down, up, up, down, full down, full up, etc etc. **** thinks I.....
Anyway, popped my head under the wheelarch to look at the sensors to see if anything is damaged and found this...
Can anyone tell me where it is supposed to go and what that bolt bolts into please. Does anyone think I am missing anything?
It is defiantly not at it's place . Did you have any type of service regarding suspension etc?
Might have missed tightening the bolt after that
It definitely looks like the bottom bracket itself has come loose from the axle. Can't remember if its bolted or welded, can you see any failed joints or a hole? To help you locate, the sensor arm should "v" out towards the passenger side wheel.
Thanks perfect!
