Mk2 Pre FL Octavia VRS
Yea mate just popped it straight on
  • Replies 192
  • Views 34.8k
  • Couple of pics from yesterday's vw vest
  • Used the DA for a full day with all the products the other day really good tool
  • Here we go again another 6 month update....   stage 2 went without a problem. new software, new full turbo back system and in larged ramair   very impressed.   also fitte
Right well been a expensive month for the car :/
Replaced the clutch (full kit)
Fly wheel
Fitted a short shifter
Had a oil and filter change
Spark plugs changed
New aux belt
New front anti roll bar bushes
New cam belt and water pump and tensions
Tracked up all sorted
£1200 :-/
AND it needs a new windscreen and wipers :-/ hahahahaha
Just had a read through your thread again Paul and wondered if you knew how much the clutch kit & flywheel would have been?  I'm sure mine will need doing before I have it remapped and I am trying to find out how much people are being charged - it seems to vary wildly for some reason.
On another note, I'm liking the red pipes you've fitted.  I haven't got round to fitting your old black ones yet though.
Well my mate who's very good
Maybe not the cheapest but very good
Got me a LUK full clutch kit and fly wheel for £600 ish then fittment was £250 I think :)
So much better now tho drives like new!!
  • 5 months later...
Right well it's been a while!!
first off cars been keep clean and now has winter wheels on
engine bay has something nice and new like a dipped camo engine cover along with extra red hoses and matching dipped battery and fuse box covers.
Also been busy with the tuning thanks to GTI in Manchester car now has stage 1 airtec intercool which has really helped at low revs and picks up loads quicker on motorway so it's win win.
also for round to fitting new rev cam and new xenons as one of mine had started to go pinky.
rear super skoda splitter is on too (not massively happy with fittment but it looks ok)
new gear knob fitted too.
Looks pretty good all in all
needs his alloys back on then roll on summer :)
I'd be interested to know what the car feels like with a Stage 2 setup.  I've currently got a turbo back exhaust and a stage 1 RS Tuning map on mine and am wondering if it's worth the extra outlay/effort to go further?
Also, do you have any pics of the intake system as again, it's something I'm considering for mine at some point?
I too bought a DA polisher but am slightly nervous of using it as I don't want to make the paint look worse than it already does.  Any tips as yours looks great?
Edited by skinnyman
That’s the best pic I have atm as it’s still a work in progress!!
as for stage 2 yea it’s defo worth it but would guess all surporting mods make it to.intercooler was a big help to keep temps down!
The DA polisher was dead easy to use and so pleased with the finish :)
Here’s the latest red hose action:)
  • 4 months later...
Ok once again a few monthly update.
followng the huge gains on the 345mm braking front I have managed to get some 310 vented rear callipers.
mainly as when looking side on the front discs fitted the wheel really well yet the rears seemed tiny....
so headed to eBay after doing some home work and purchased a set or R32 callipers. Currently in the process of refurbish them and they will be fitted hopefully in the new year some time.
Also I was never a fan of the black metal intake pipes. Had a set made up in alloy along with the prone to break Y coolent hose/block :) when fitting these I will also be fitting the full set of creation motorsport coolent hoses.
Can will be cleaned by the valetor now as I would be getting cold or wet over winter :)
So here I go again
not really monthly but you get the idea
so after a full service and new plugs and packs.
The rear 310mm kit is on and it’s a most for those who have done the 345 fronts
the car no longer nose dives when heavy braking.
havent washed or done anything with car :/
kinda missing it
off for most of this month so will get it polished and cleaned
  • 5 years later...
Totally forgot to keep this thread alive…..
so some of you might have seen my car on instagram but during and just after the lock down, I sent the car away.
Was with R-tech for 2 weeks…
Came back a totally different car….
now has a venom 350 hybrid turbo, ko4 injectors and all hardware to suit, custom map running now 350bhp.
Also has the K brace and under body braces upper front strut brace.
LE seats which are far better than standards.
some decent work on this and looks clean as
Cheers man :)
yea it’s pretty clean :)
18 hours ago, Paulbrown said:
Cheers man :)
Good that your local too , rare to find a looked after clean example (i've looked as i wanted one)
Yea man Selby/York area
I have been to the motorist hub quite a bit.
there’s a few of us in ŠKODAs who head that way regular
must make an effort to visit as only Huddersfield
Edited by dubDEAN
