Waxing.
Which wax polish do other owners find best? I've always just used wash 'n' wax, but feel that the Citigo might appreciate a little more cossetting. Thanks.
I am a big fan of the auto glym range. Others will say some other products it totally depends on what you like.
For me the AG range is good value easy to use and is readily available :)
Best bet is to get to halfords and see what takes your fancy.
I washed polished and waxed mine the other day and well the rusults speak for them self in my progress thread :)
I've been using this:71So3USDOML._SX425_.jpg
+1 for AG range,
tried cheaper ranges like simoniz etc and nowhere near the AG range results, you can go more expensive but at the end of the day it is all down to preference and budget (also how much time it takes to apply)
Hi
I assume you mean wax and not polish...two different product types + there are sealants
However' I'm not going to give you a recommendation because there are may different favourites
Firstly a couple of questions:
1. Do you have a budget? They range from a few quid to over £2000 !!!
2. How often do you wish to rewax? Some are more durable than others
Crucial questions when deciding what to buy
May I suggest that you read these guides:
http://www.polishedbliss.co.uk/acatalog/choosing-paint-protection.html
Then have a look at their waxes and see what falls into your budget or takes your fancy
http://www.polishedbliss.co.uk/acatalog/natural-carnauba-waxes.html
or here
http://www.cleanyourcar.co.uk/wax/cat_4.html
Any more questions..Please feel free to ask
I love this stuff [emoji106][emoji4]
+ 1 for the sonax detailer. Use this pretty much after every wash
Sonax protect & shine is the way to go. ;)
I've found nothing better than Greased Lightning Showroom Shine - saw it some years ago on one of the TV shopping channels. It's supposed to be used to clean and polish the car without the use of water, but I use it after I've washed and dried the car - it gives me an excellent shine and is brilliant for removing tar spots etc.. Have tried everything else including carnauba wax but the Showroom Shine gives me the best finish and is so easy to use.
We used that lightening stuff when we were on TV on the rrv did work really well
Have no exp of using it on my own car tho :)
I tend to just shave, waxing is a bit painful
I was waiting for the last comment! Thanks for all the answers; I'll have browse around Halfords next time I am passing it. I am still not entirely  clear about the difference between polish & waxing - don't they do the same thing? (excepting the final comment of course)
@ snapseller
Polish contains a varying degree of abrasives to 'cut' away microns of paint to shine the surface
Light polishes are primarily used to remove contaminents and some contain fillers to mask fine scratches and lay down a small amount of protection (AutoGlym Super Resin Polish does this)
Other polishes are designed to work with polishing pads, primarily sponge or Microfibre, to cut away a layer of paint and remove fine scratches
Its usual to use a light polish afterwards to further enhance the paintwork with a light finishing pad...prior to waxing
Waxing, lays down a layer of wax that further enhances the shine and protects it against environmental damage, such as acid rain, UV light, road salt, water spotting in hard water areas.....etc....
It also makes the car a lot easier to clean and dry afterwards
Have a read of this:
http://www.polishedbliss.co.uk/acatalog/what-does-polishing-do.html
@ snapseller
That's a good article but unless I missed it there doesn't seem to be any reference to claying?
Fred
Yes they're very good on light contamination...I use plenty of soapy water, but you can use a QD/Clay lube as well
I love this stuff
Bought a bottle from Amazon on the strength of this post and used it for the first time yesterday. Quick wash and squegee and then went round each panel giving each one a couple of squirts and and rub over with a microfibre cloth. It's rained cats and dogs here this morning and the rain is 'balling' and standing in the biggest drops I've ever seen. I'm a convert :D
p.s. emoticons don't seem to work in quoted text??
Edited by longedge
Have also ordered a bottle off Amazon,look forward to giving a go when it arrives.
Thanks, I did a little online research and these seem to be getting a lot of thumbs up, bought one today, just need to wait for the rain to go to try it out!!!
As ChrisRs advised you can use soapy water as the lubricant or a Quick Detailing spray. Be sure to keep the area your working on wet as the clay mitt will drag otherwise.
