Brake upgrade
My friends selling some tarox 6 from a mk4 golf. Will they fit on my mk1 fabia or will I have to change my hubs??
I got them aswell m8 they are a straight fit awesome brakes!
Tarox is a modular braking system so you can almost certainly buy the appropriate caliper carriers to fit them, how big are the discs they're designed for?
Yep they will swap across.
330mm you'll need 17" wheels mind
Ok sweet thanks for that
323mm is the normal size disc.
They will fit behind standard 16inch vrs alloys, but you will need spacers and no balancing weights on the inside near spokes!
Also worth noting not all 17inch alloys clear them, my TD pro-race 1.2's in 7x17 don't clear the caliper without 12mm spacers.
330mm discs will fit behind 16" wheels with spacers I tried it but didn't want to run spacers hence sold the 16's and got spiders with no spacers
