****ing swimming pool in the footwell
Noticed a bad smell a few days ago. It was so thick and mouldy that i thought something had crawled under the bonnet and died.
Had a closer inspection last night when i took everything out of the car. In the rear passenger footwell on the drivers side i found a puddle of water when i lifter the mat. The floor was soaked through from the bottom up.
Have to phone the dealer this morning, but i don't think its going to be straight forward, carpets, linings etc.
Has anyone else heard of or experienced this??
Not a happy camper :mad:
JD
Rear passenger footwell is the quiet common problem of the door seal not sealing properly. May also be worth checking that the drain holes in the bottom of the door are not blocked.
It could well be water leaking through a mis-fitted pollen filter
In the rear footwell?????
It's really starting to stink. I think i will be requesting the car is valeted when they have corrected the problem.
i had this mate last week its where leaves and gunk block the drain plugs under the bonetnear the wippers it starts to coming out the air duct under passenger seat i had a swimming pool in the back! take it to skoda mate.
