fault code on '08 octavia?
Hi, having run the climatronic self diagnostic test i get 525 04h... can someone tell me what this means as i dont know if i'm reading the ross tech code list correctly. Air con does not provide cool air.
Many thanks.
  • 10 months later...
+1
same here today
hexadecimel value 525 gives 1317 decimal value which is (maybe):
http://wiki.ross-tech.com/wiki/index.php/01317
I don't know about this 04.h on the right-hand display
any ideas?
I've never tried to do self diagnostics via the climatronic panel but I think the 04 is the number of faults stored, to view the others I think it's up/down temp (not sure if it's left or right).
I'm also not sure if the climatronic can clear the faults. This means they may be old and not relevant to any problems you're having - I would suggest getting a proper scantool on the case such as VCDS :)
no, it's the only code, there's just one fault - this above  :|
solved
it was faulty 1K0959126A - Air Conditioning Pressure Switch Thrust Sensor
now it's ok
