Protecting against corrosion
Is it good practice to spray some of the engine components with a bit of WD-40 to protect against corrosion? I noticed some of the clips, alternator casing and other fixings were starting to get spots of rust etc
any ideas/suggestions on best way to do this much appreciated :thumbup:
Matt
Personally i do spray the clips and connectors. Don't go mad though and don't spray the alternator casing as some will get on the windings - can cause hot spots and premature alternator failure.
ACF-50 is the best anti-corrosion spray I have ever used, keeps my bikes pristine and I use it on bit's and bobs on the car. It's not cheap (in relation to WD40) but it does not wash off and forms a semi permanent protective barrier.
Busters motorcycle accesories have been the cheapest I have found for it
http://www.busters-accessories.co.uk/proddetail.asp?prod=AACF50
1 tin would easily last you a year or more.
Fluff'
You can get more of the ACF stuff from here, as well as their other stuff too.
http://www.jaws-motorcycles.co.uk/acf.htm
Bit of a cheaper option is Scott oil FS365, I tend to use this on the car as well as the bike. Bike show special this week is 6 litres for
