octavia vrs
hi can any body tell me wear my ecu is in the car it is a octy vrs and do you need a tool to change the rear brake pads cheers
Welcome to Briskoda, sorry to here of your troubles, hopefully Lummox will be able to help with your query.
Is the vehicle remapped?
Welcome to the site
Welcome to Briskoda. :D
hi not sure no being remapped but it as a mtm audi racing chip in it it is very fast my mate as had is done to 230 bhp and mine leaves him standing can you help light as come on again today skoda tell me it is the ecu but i have lost no performas in the car what so ever can you help please
What mods apart from the chip?
only the chip as been changed as i know all the rest standard
If it has a chip then it has been remapped (same thing)
16985: Internal Control Module: Memory Check Sum Error
That would typically be caused by a bad chip or a bad chip installation.
ok i have had the car for 12 months and the light as not come on until the miss fire which i changed the plugs and then it turned out to be a coil in number four changed that then ok for 4 weeks then this 16985 internal control module fault so do i need a new chip in it
If you have older coils than J prefix then all of them should be changed by Skoda to the new sort free of charge,
If the light has come up again with 16985 then I would assume that there is a fault with the replacement chip.
If you have older coils than J prefix then all of them should be changed by Skoda to the new sort free of charge' date='
If the light has come up again with 16985 then I would assume that there is a fault with the replacement chip.[/quote']
ok cheers which chip would you put in it and were can i get one from
hi were can i get a chip or remapped ecu to check my ecu as a have the engine light keeps coming on with 16985 internal mod fault can any body help please
  • 1 year later...
hi
i have the same fault code but my car does not start,
does your car start ok?
i am starting to think my car is proper bust.
billy
