Brake Warning Light On
2.0 TDi , brake warning symbol on dash ( O ) , scanning with VCDS shows no fault (doubt pads worn as relatively new ). Oddly when scanning the module the cluster shows ESP fault (Clears when scan complete). Any ideas ? I'm thinking the pans are actually worn or a broken wire/dodgey connector ?
Could be the abs wheel sensor, this is linked to the esp and throws up dash lights when it can't get a reading for the control ring on e wheel hub. I jet washed my wheels and he problem went away so must have been jammed up with dirt or rust
Brake pad warning is a simple circuit it doesn't leave any error code in the system.
I had the light come on with brand new pads although it went out and never came back.
You can remove the wear sensor without any problems apparently, there will be a guide somewhere else round here.
ABS error will be something else. Might have been something as simple as a bit of mud on the reluctor ring.
Have you visually inspected the pads?
