Touchup Paint Help - Please
Hi All,
My new Yeti has a scratch on the lower plastic trim running near the sill on my drivers side, it was caused when i had to have some additional work done at an auto electrics place. Not worth complaining, so could do with a touch up stick to fill it in.
I can't seem to find my paint code online, i have LF7Y (i think seda metal/metal grau?) as the main colour and F61Z on the roof
Can anyone help me out at all? The colour to me is gun metal grey
The code on the table in the boot states
LF7Y-F61Z
I would really appreciate some help,
The 1Z is the Black Roof if that is what you have.
So for the Body Colour just use the other Code to give the Supplier.
When I got mine from a Skoda dealer online I had to put my vin number in so they got the right code for the paint
Problem with some of the manufacturers touch up sticks is the paint has the constituency of treacle. Use the Chipex product myself, expensive and not quite as good as they claim but its far better than a thick unsightly blob.
TP
Halfords will make it up for you if you need it quickly:
Car Paint Mixing Service
Using our 48 basic mixing colours and your vehicle manufacturer's formulations, Halfords can provide you with a professional quality colour match and can offer you every colour under the sun.
Halfords can provide you with paint to match the colour of your car so long as you have the colour code information from your vehicle. Colour codes are normally found on the identification plate, which can be located under the bonnet, in the boot, or inside the door frame on the driver's side of the vehicle.
When you have given us the colour code, we can then provide you with a matching paint. Halfords supply car paints in various forms such as touch up tins, aerosols, 500ml and 1 litre tins for spray guns.
Halfords specialist car paint mixing service starts from just £9.99 (€11.99), and is only available in selected stores.
