sonax finnish
How much product would you normally use on a large vehicle,not to badly scratched also what time scale per panel.
I cant say...nobody can...Not a lot
I assume you mean this:
If using that on a Superb, for example....with washing, drying, decontaminating and polishing then protecting with sealer or wax...Its going to take 6 hours minimum..with help
On my own..it would probably take as much as 9 hours
Again, it depends on the level of finish the client wants..I would use that polish as part of a two stage process, using a medium cut prior to that, not usually on its own, unless its a new car
Yes thats the stuff chris i bought the tube on your advise, done boot and bonnet today took an age and very dusty stuff. Pleased with finnish would you polish and wax before a sealant.
LOL..I didnt think it was dusty..you might have used too much.
Once you've polished, apply some diluted IPA with a MF cloth, next use sealant and/or wax..in that order
Wax always last
If it is dusting you've definitely used to much buddy.
One thing with Perfect finish, it clogs the pad up very quickly. So spur the pad regularly. Do this by spinning the pad off the paintwork and use a tooth brush to clean the pad as it spins. It should fly off it.
If you're not getting enough cut, try going for a more aggressive pad. PF is very pad dependant. Great polish that will get rid of some serious imperfections, very versitile.
Yes thought it may of been pad but was brand new white rupes , but was unbelievable dusty only put 4 pea size blobs on after primeing the pad.
Maybe because cars silver and couldnt really judge, working outside as well.
