Cracked flywheel
Just joined, hope I can stay as I am a Banham Spyder owner.
I am having my 135ric engine rebuilt, (Bendick removed) when the chap tells me that my flywheel has a crack in it, can anybody tell me if I can replace the one with the crack in with one from a Favorit or similar.
Many thanks
Ispyme
Yes and no. If you are not using Bendix and you are using a carburettor, you can change it with a favorit-felicia one but you have to use the crown gear (starter teeth) from the old one because they are different. So you can not just change it without changing the crown gear because your starter wouldnt work. The crown gear is compatible with favorit - felicia flywheel from all old models 1000 MB - 100 - 105/120 Estelle with 180/190 mm clutch. I hope this help.......
Many thanks for your reply, I have now acquired a 130 flywheel with crown gear.
