Front Map lights
Does anyone know how to get to the bulbs in the front map lights?
The rear light was easy but can't see any obvious bits to release the two discs covering the map lights.
I know on other manufacturers you have to remove the whole unit, if this is the case any tips on how to do this?
The clear plastic just pulls off. You have to be brave but mine came away no problem.
I used an old credit card
Insert it into the gap (red arrow) and pull it to the left in the gap (green).
This releases the front bits and then you can remove the cover.
Took me 30 secs without braking or scratching anything:)
Thanks will give it a try
