What bhp should I have?
Hi
I have a 53 plate fab Vrs with full decat with no boxes, seat sport fmic with hard pipe, egr delete, md376 turbo, s2000 air filter with pd160 feed.
and hopefully a remap :P
My bet is 220bhp.  The MD376 is key,  Decent stage 2 PD150 hybrid.
exactly the same as mine was and mine ran 223bhp
Yes a map
What do I need to do to get nearly 280
Gtb2260 hybrid, maybe even a slightly larger one ... And 280 will require bigger nozzle injectors, 260 is ok on standard injectors.
And a map. That should be it.
im 280bhp
im 280bhp mail me for info
Upgraded clutch, a diff is essential if you want to use any of the power
brakes to stop it, suspension to cope with extra power
...and thousands of pounds plus a new top end when the head cracks  :p
Edit: You should have a THOUSAND BHP at least, I should have thought.
Edited by sepulchrave
and if u need a head mail me I have 2 spare atm
Just had dyno and got 208.9bhp and only 311ft torque?
Sounds good, should be nippy :)
Is that all?
Blimey, I'd demand a recount or a refund or something else beginning with 're'!
Could well be a safe map.  Any idea what boost level its running?  To achieve 220+ you usually need 1.8 - 2.0 bar of boost.
mine was 1.9 bar
I got 230bhp (think it was 325 lbft) @ 2.1 bar with similar mods, however only had a decat on stock exhaust and home made intake+snorkel and stock air filter.
This was on an accurate reading dyno Dynamics rolling road.
2.1 bar is max I'd say.
Hybrids are old has been turbos now, turbo Dynamics are decent but give me a gtb any day.
turbo dynamics say the mdx-376 shouldn't be pushed more than 2 bar max
That's true if you read their literature on Web site etc to protect warranty claims, I know olly (who used to work there) many have ran more than 2 bar for years, I wouldn't run more than 2.1 though but he told my folk have.
Boost at 2 bar
Possibly couple of reasons
*most likely
*Depends on dyno pessimistic dyno
It isn't 2 bar
Hot day or heat soaked
*Hasn't pushed the fueling side of the map need to smoke to get best power
Other car related issue
